Set Prob temp message
Hello!
My KitchenAid Superba Double Built In Oven Model # KEBS277DWH1; Serial # XF3501073, is showing a SET PROB TEMP message in the digital screen. With a picture of a funny looking thermometer. It first showed up last weekend and some how is stopped beeping and went away. It is back now, I can still turn the oven on. Any insight would be greatly appreciated. I can not find the manual.
Thanks!!
Annie
[quote=AnnieD;528827]Hello!
Thanks!!
Annie[/quote]
Annie,
Your oven ERC, thinks you’re using the meat probe temperature option.
You most likely have an issue with the meat probe jack in the oven
AP3889293
You can try installing and removing the meat probe a few times, it works occasionally. Otherwise you’ll need to test or replace the probe jack.
Here is the manual
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%204450571.pdf
Try unplugging or flipping the breakers off for 5 minutes or so to see if it will reset/fix itself.
