SEnsor light not working on the ice maker
Brand:Thermador
Model Number:KBUDT4850A02
Main Symptom:Not making ice
Has anything been replaced or any checks/tests been made?
WE replaced the ice maker about a year ago and it had been working great until recently. The sensor light doesn’t light up so I am assuming the sensor has gone bad.
There’s usually a pretty good chance that the ice level sensor boards W11629974 are causing the issue. I would recommend making a voltage check at the icemaker just to be safe. At the icemaker harness you should be able to check for AC voltage from black to white wire with the door switch and ice level switch taped down, just make sure you aren’t blocking the beam path between the emitter and receiver boards.
You should be getting 120v AC, but it may be lower or higher. If the voltage is present but anything less than 110v ( I’m talking up to and including 109.9v) then the issue is with the ice level sensor boards.
If that voltage isn’t present at all I would recommend making a voltage check at the larger of the 2 boards of W11629974. At that board you’ll check from the light blue with black tracer wire to solid white wire for 120v AC. If voltage is present replace the ice level sensor boards.
