Hello!
We have a Whirlpool Gold Accubake System oven, Model GBS307PDQ9.
My wife run a self cleaning cycle, and since that adventure, the oven does not work anymore.
All the electronic part of it seems like working fine, but it doesn’t heat up at all.
I was reading at your articles where it seems like a lot of folks are having the same type of problem; But I decided to contact you and ask due to that there maybe different parts that are applicable based on the Model.
Sounds like the high limit thermostat (Item 37 in Section 1) has opened.
I would check the power to the unit first. Electronics and lights only require half the line (120 volts) whkile the elements require bothe sides (240 volts)
See bootom of this post,
Looks like this is sold as single or dual oven units.
Remove power from the unit.
Remove one wire from the thermostat and check it with a meter.
Should be 0 ohms.
Power Check
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
