Self Cleaning option doesn't function
Brand: GE
Model Number: JB640SF3SS
Main Symptom: Self Cleaning will not operate.
What happens & when: Lock over door and press the Self Cleaning option and nothing happens.
I tried a new control panel, not sure if I’m using the right Code. I replaces the whole locking mechanism and the temp sensor and nothing changes the functionality.
Error Code (if any): None
Ge WB27X45466 Electric Ranoven Control Board OEM Part - not sure of the right code though
Ge WB21X22134 Oven Temperature Sensor Assembly OEM Part
Ge WB14X41386 Randoor Latch And Handle Assembly OEM Part
Your programming code is 32, try that and see what it does.
so it display a flashing LF4 H25 code but after a minute or so goes to clock. Tested Self Clean and now it seems to work.
