While plugged in and idle the dryer suddenly began beeping and the control lock light flashing every few seconds. None of the buttons would work at that point, although pressing and holding some of them inhibited the blinking and flashing until released, but then it began again. The standard control lock release method of holding the complete signal button down for three seconds, as described in the manual, didn’t work, even when held down for a long time.
After being unplugged for a few hours and then plugged in again, and my pressing a few buttons at random (I can’t remember the sequence), the control lock light went out and the dryer was able to started normally. It already had clothes in it ready to go. However, while it was drying, the blinking and beeping began again, although this didn’t seem to affect the drying. I didn’t look at the dryer while the drying was going on, so I don’t know if the lights went out when the beeping started. From time to time I could hear the beeping stop for a minute or so, but then it began again.
Once the cloths were dry, at which time there was still beeping and flashing, I unplugged the dryer again for about an hour, and when I plugged it in afterwards it was silent, and pressing the “control on” button did illuminate the time display. But after only a minute or so, the beeping and flashing started again and the buttons no longer worked.
From searching around, it seems that the problem is the button panel or the control module. I don’t know whether it is worthwhile to try, during the brief period after plug-in, to enter diagnostic mode and see if I can find some error codes.
It is odd that the machine started doing this when it was idle. Also, I don’t know why it would stop beeping for a while and then start again. It sounds like an intermittent problem or something dealing with poor electrical contacts, but it could be anything.
If would appreciate any advice on what to do next. Replacing the control module is expensive. The dryer does seem to work if I hurry to start it after plug-in following a long unplug time, and ignore the beeping, but I’d rather try to fix it.
