[LEFT][FONT=Courier New]Hi, I’m new here and want to thank you in advance for your help. This is a great site! [/FONT]
[FONT=Courier New][/FONT]
[FONT=Courier New]I have a Sears Kenmore Series 80 gas dryer (made by Whirlpool?), Model # 110.97283100, purchased new in 1993. The problem is that the unit does not run. When the problem first surfaced, pressing the Start button would cause a hum, but now it does nothing at all. The unit has been cleaned of dust and lint, the belt is OK, the circuit board looks OK and the 120V wall socket is OK. [/FONT]
[FONT=Courier New]I have checked the Push to Start switch, Door switch, Thermal Fuse and Broken Belt switch; all show continuity. I can grab the Blower Wheel and turn the motor, but it’s fairly tight and does not spin freely. Is it possible to check the Motor switch or the motor itself directly w/a digital multimeter? Does it sound like I have a dead motor? The Kenmore P/N for the motor is 3391890, which I understand has been superseded by P/N 279787. Any suggestions?[/FONT]
[FONT=Courier New]Thank you very much.[/FONT][/LEFT]
