I have a sears clothes washer that has stopped agitating, I feel that the coupling between motor and transmission is a fault. I need help on the part number and instructions:) on how to go about fixing it myself. Every thing else is in working order it just does not want to agitate, will spin, and empty the water.
Through looking around on the internet I found a site which explained how to remove the outer housing of the clothes washer and repair the coupling between the motor and the transmission which was the problem. A local Sears Parts center had the $15.00 part and I have installed it and it works great. Good luck to you all…![]()
