Brand:KenmoreModel Number:110.27612600
Main Symptom: washer leaks water
What happens & when:replacing seals
Whats the easiest way to replace 285203 on a kenmore 110.27612600? It leaks water when filled passed the half mark or small load im thinking it just needs the upper agitator seal and bolt with rubber gasket. Though it may need the outer spin tube seal and other 3 seals that are in the 285203 kit. Is there an easy way to remove these and install them? From what i can tell two of the spin tube seals can be installed from the bottom with the original bearing? What grease or lubricant is used on the seals as they have grease retention grooves?
