SE error and keypad will not respond
I got a error code of SE on my microwave, then I unplugged the unit then plugged it back in again. The display said to press the clock, but the keypad would not respond. Can you tell me what’s broke or needs replaced?
I replaced the Keypad already, but now nothing happens. It’s like it’s not plugged in when it is?
The SE code on your microwave is for a Key Short Error. You will need to replace the key pad. Here is the part number for you. Hope this helps. AP5322471
I replaced the Keypad already, but now nothing happens. It’s like it’s not plugged in when it is?[/quote]
Did you test the fuse?
