when machine comes to a final stop it makes a loud screeching noise
thank you
dave
[LEFT][COLOR=#000000]It sounds like you have a bad brake assembly. In order to do a proper repair you will need a new brake, stator, and snubber. Also when I change these I change the thrust bearing kit as well. This will fix your problem. If you do not repair this, it will start to slip so bad that the agitation will not work properly. Here are the part numbers you will need as well as a link to the parts diagram. Hope this helps.[/COLOR]
[COLOR=#000000]Part number: AP4373023 [/COLOR][/LEFT]
[/COLOR]
[COLOR=#000000]Part number: AP4045273 [/COLOR][/LEFT]
[/COLOR]
[COLOR=#000000]Part number: AP4024496 [/COLOR][/LEFT]
[/COLOR]
[COLOR=#000000]Part number: AP4009132 [/COLOR][/LEFT]
[/COLOR]
[COLOR=#000000]Transmission replacement parts for AMANA NAV5805AWW WASHER-TOP LOADING | AppliancePartsPros.com[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Read more: http://forum.appliancepartspros.com/washer-repair/173884-2-issues-noise.html#ixzz1EDz13nTS [/COLOR]
[COLOR=#000000]http://forum.appliancepartspros.com [/COLOR][/LEFT]
