Screen only shows "Turn Dial" and no functions work after replacing Control Board
Brand:
Model Number: PSB1001NSS01
Main Symptom: No buttons work and it only shows “Turn Dial”
What happens & when: The screen was blinking erratic and would blank out. The only function I could use was the 30 second quick reheat. I replaced the digitron about 6 mos ago and the screen was brighter and some of the issues cleared up but not all. It still blinked and while cooking the screen wouldn’t show anything. When it was done cooking the screen would show again. Today I replaced the microwave control board and now it only shows “Turn Dial” and no other buttons work. I put the old control board back in and now it shows the same thing “Turn Dial”
Error Code (if any): None
Parts or tests already tried: Digitron & Control Board, See above
Photos / video link: NA
Hi Cisaacs, thank you for your post.
Since there are three different control boards in this model that can influence operation in this way, could you confirm which specific control board was replaced? If possible, please provide the part number of the control that was installed.
That information will help narrow down where testing may need to begin.
Hi William,
Good morning and thanks for getting back to me. The part number that I replaced was (WB27X10858). After letting the microwave sit for a while it let me set the time etc. Now it is working again with button functions but it’s still blinking erratically and the screen goes blank while cooking. Thanks!
v/r
Clif
If the microwave can be set on a countertop, the top and side panels can be removed to allow access for voltage testing. This will help narrow down the cause of the failure. For this test, needle lead probes will be needed to safely reach the terminals.
After the panels are removed, locate the low-voltage transformer connections going to the power control board at connector CN7.
With the power cord plugged in, use a multimeter set to Volts DC and take the following measurements:
  • Yellow wire to black wire — should read about 12 Volts DC
  • White wire to black wire — should read about 19 Volts DC
  • Red wire to brown wire — should read about 7 Volts DC
Do the voltage readings differ from these values when you perform the test? Let us know what readings you find and we can help determine the next step.
Good afternoon and thanks for your help. I’ve finally had time to get to this test. I just pulled the panel off and noticed my low-voltage transformer doesn’t have a brown wire. I have Black, White, Yellow and 2 Red. I’m not sure if i’m doing it right, this is what i’m getting.
Yellow to Black 1.3V DC
White to Black 2.0V DC
Red to Brown (Mine has 2 reds) 1.8V DC
**WB27X10861 Power Control Board shows signs of heat. It looks discolored.
Thanks!
v/r
Clif**
The last check would be verifying that the low-voltage transformer is actually receiving the voltage needed to create the DC voltages for the appliance.
There should be a white wire and a black wire running from the relay PCB connection CN1 to the low-voltage transformer. With the unit powered, those wires can be tested for about 120 VAC.
  • If you do measure around 120 VAC, then the transformer is receiving the proper input voltage but is not producing the DC voltages needed for the appliance to operate correctly based on the readings you found.
If that’s the case, unfortunately it appears the low-voltage transformer has been discontinued according to the part information page linked here. WB17X10021 Transformer Power | Genuine Ge OEM In Stock
