Samsung WF45K6500AW/A2 front loader washer won’t accelerate to spin
Brand: Samsung
Model Number: WF45K6500AW/A2
Main Symptom: drum rotates but won’t initiate spin cycle
What happens & when: gets to spin cycle and won’t ‘take off’
I couldn’t get the load to spin So I took it out and ran a few empty drum rinse and spin cycles with the same result - the water drains, the light switches from rinse to spin but the drum just kind of turns a few times and then stops over and over and the time doesn’t run down completely , keeps resetting. The drum turns fine by hand but does seem like it could be favoring one side. The water drains but when I took the filter out to check it there was soap residue, as well as the towels that were in the wash being not fully rinsed.
This all started after I ran the self cleaning cycle and took the filter out to clean it. Not sure if it’s related. I also washed a big blanket that gave me the first UB code but then I did a regular load done and then the towels after that are when it started with the issues.
I’ve narrowed it down to a drain pump, hall sensor or motor/ stator I just want to make sure before busting it open and ordering parts I’m on the right track .
Error Code (if any): gave me Ub a couple of times but no code since.
Parts or tests already tried: none.
Try spinning the tub by hand. If you hear a grinding noise or it sounds like sand or small rocks are rolling around, the bearings may be worn out. Depending on the condition of the washer, you might be able to get away with replacing just the shaft assembly if the spin basket wiggles around in the tub and there is no grinding noise, but if the bearings are damaged, they will likely need to be replaced as well. Unfortunately, the bearings would only be available as a part of the rear tub assembly which has been discontinued by the manufacturer.
Spider shaft- DC97-16509C Washer Drum Shaft Assembly | Genuine Samsung OEM In Stock
Rear tub assembly- DC97-19673A Semi Tub Back Assembly | Genuine Samsung OEM In Stock
