washer started to fill with the first washlight on and then just quit.now when you try to restart it just humms and wont do anything.![]()
Model Search
Here is a manual although it is not a match to your unit it is probably close with a little luck the diagnostics etc. will be the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2?OpenDocument
