Samsung washer wont start cycle
Brand: Samsung
Model Number: WF50A8600AE
Main Symptom: Washer wont start cycle
What happens & when: The display works fine but when I push the start button it makes a beep, but never initiates the cycle. The child lock is off, the Door latch is open, the water has been drained. When I run the diagnostics I get error code 9C2, so Im thinking it might need a new Power Control Board
Error Code (if any): 9C2
Parts or tests already tried: Manually unlocked Door, drained washer, Factory reset washer, power cycled device,
The 92C would be a power issue and you would want to check the power supply. The most likely cause for this if it is getting proper power to the unit would be a faulty main control board.
Could you guys provide the part number for the power supply. THX
The power supply is the home supply where it is plugged in at and where it connects to the dryer.
