Brand: Samsung
Model Number: WF448AAP/XAA 04
Main Symptom: Won’t spin, just sits in a puddle of water. They drum rotates freely though.
Error Code (if any): No error code
Photos / video link: I thought maybe a belt would be off or broken, but it doesn’t have a belt.
Based on the description if it just sits you could have a door switch issue, or even a control board issue. You will need to test the door switch with a multimeter and the board for power in and out with a multimeter.
[AppliancePartsPros.com]
(Washer: Troubleshooting Common Washer Problems & Solutions)
Do you have a video on how to test these with a multimeter?
