Samsung washer power button and control panel replacement
Brand: Samsung
Model Number:
Main Symptom: Power Button Won’t Turn on
What happens & when: Power button does not work unless I unplug it and plug it back in again.
Parts or tests already tried: Purchased display board from this But still does not work. Need a new part or faulty part given.
Hi arpaauwe,
Could you please provide the model number of your appliance? That will help me look up the correct parts and troubleshooting information so I can better assist you.
Model number WF45K6500AV/A2
Why is this taking so long to respond?
Track Order #17159080
Order date:
6/20/2026
FedEx tracking number:
382190775280
Ship date:
6/23/2026
Shipped to:
[address removed]
| SAMSUNG Washer Display Control Board Assembly |
| Part #:
AP6002441 (DC92-01802L) |
Ship Date:
6/23/2026
Quantity:
1
Based on the information you provided, here are the possible causes for each error code and what to check:
Button Error
  • A button or switch may be stuck or jammed because it is being pressed unevenly due to a deformed control panel or button.
  • A button other than the Power button may be stuck for more than 30 seconds.
  • An internal plastic component may be deformed, causing the button to stay pressed.
  • The screws securing the sub PBA (control panel board) may have been overtightened, putting pressure on the buttons. If so, try loosening them slightly and check if the issue goes away.
AC2 – Sub PBA Communication Error
The main control board is not communicating with the sub PBA (control panel board).
  • Check all connector connections between the sub PBA and main PBA for loose, damaged, or improperly seated connections.
  • Remove the sub PBA and inspect it for damaged or cold solder joints.
AC3 – DR Module Communication Error
The main control board is not communicating with the DR module.
  • Check the wiring harness and connectors between the DR module and the main PBA.
  • Inspect the DR module for damaged or faulty solder joints.
AC4 – Wi-Fi Module Communication Error
The main control board is not communicating with the Wi-Fi module.
  • Check the connector and wiring between the Wi-Fi module and the main PBA.
  • Remove the Wi-Fi module and inspect it for damaged solder joints.
AC5 – LCD Module Communication Error
The main control board is not communicating with the LCD display module.
  • Check all connections between the LCD module and the main PBA.
  • Inspect the LCD module for any faulty solder joints or visible damage.
AC6 – Inverter PBA Communication Error
The main control board is not communicating with the inverter board.
  • Check the wiring harness and connectors between the inverter PBA and the main PBA.
  • Remove the inverter board and inspect it for damaged or cracked solder joints.
Since you’re seeing multiple AC communication errors, I would start by checking all of the wiring harnesses and connectors between the boards. Look for any loose connections, corrosion, or damaged wiring. If everything checks out, inspect each board for burned components or cracked solder joints. A failed main control board can also cause multiple communication errors if all of the connections are good.
Thank you for responding. I am going to call service on this at this point.
