Samsung washer not spinning
Brand:Samsung
Model Number:WA52A5500AC
Main Symptom:will not spin
What happens & when:when the washer gets to the spin mode you can here the motor spinning but the drum doesn’t move.
Parts or tests already tried:I put the washer in Cb mode and the drum would move
If the washer will spin properly in the calibration mode, it is very likely that the main control is not activating the clutch motor when it should. The clutch and clutch motor may need to be checked to make sure they are not damaged, as well as the splines on the spin basket. IF that all looks good, the main control would be the likely cause of failure. DC92-02965P Washer Inverter Control Board Module | Genuine Samsung OEM In Stock
