Brand: samsung Model Number: wm3570hwa Main Symptom: leaking What happens & when: leaks down the front door while running. Leaves a pretty nice puddle.
Error Code (if any): none
Parts or tests already tried: unclogged the drain hose
If the leak is starting at the bottom of the door, there are two common causes. The first is a piece of debris on the door that breaks the seal. Those of us with dogs or cats run into this a fair bit, and their hair will stick to the door and break the seal. Usually, just wiping the door thoroughly will remedy this. The second common cause is the door gasket being damaged. If there is a tear in the gasket where it seals against the door, it usually will allow water to leak past.
I think it was pushed too far back into the space. I pulled it out a smidge and it hasnt leaked. I think the drain hose was binding. Now I just need to find the sweet spot.
