Brand: Samsung Model Number: WA54R7600AC Main Symptom: Stops midcycle, will not power on again, effectively dead What happens & when: Start a cycle, will not hear noise or code, come back and door is locked, washer is completely dead (display inoperable)
Error Code (if any): NONE
Parts or tests already tried: Pressure sensor, door lock harness, PCB is receiving 120V power
The only thing I can add is that this is the 3rd time it’s happened, the after messing with it enough, (resetting pins and testing components) eventually it will come back on and can even go multiple cycles without it locking up again. I let it drain overnight to see if it was a drainage issue (I also made sure the drain hose was good) but it still wasn’t on, leading me to be confused on what component it could possibly be. There isn’t any burns on the PCB so I’m reluctant to just replace it. Any ideas?
For your Samsung WA54R7600AC washer, I would concentrate on the main control board, its power supply circuit, and the wiring between the main board and the display.
The biggest clue is that the washer stops in the middle of a cycle, the lid stays locked, and the entire display goes dead. Then, after disconnecting and reconnecting components, it eventually comes back to life and may run several cycles normally.
That sounds more like an intermittent electrical failure than a drain, pressure sensor, or lid lock problem.
Also, a control board can fail without showing any visible burn marks. A failing voltage regulator, solder connection, or electronic component can cause exactly this type of intermittent shutdown.
Here’s what I would check next
1. Check the incoming voltage while the washer is dead.
Since you’ve already confirmed 120 volts at the PCB, that’s a good start. However, I’d repeat that measurement while the washer is actually in its failed condition.
Measure across the board’s incoming Line and Neutral connections.
You should have approximately 120 VAC.
Check whether that voltage remains steady when attempting to power the washer on.
If the board has a steady 120 VAC supply but isn’t responding, that points toward a board or communication issue.
2. Check the display/control panel connections.
Unplug the washer first.
Locate the wiring harness connecting the main PCB to the user interface.
Disconnect and inspect both ends for corrosion, loose terminals, or damaged wiring.
Look closely for terminals that may have backed out of their connectors.
Reconnect everything securely.
Because you’ve mentioned that the washer sometimes comes back on after manipulating the connectors, I would pay particular attention to this harness.
3. Check whether the control board is producing its low-voltage supply.
This is probably the most useful next test.
The main control board supplies low-voltage power to the display and other electronic circuits.
If the board has 120 VAC coming in but isn’t producing the required DC voltage for the display, the main PCB becomes the leading suspect.
The exact connector pins and expected DC voltage should be verified against the wiring diagram for your model before testing.
4. Check for an intermittent connection.
If the washer powers back up, try gently moving the wiring harnesses one at a time while observing the display.
If the display flickers or shuts off when a particular harness moves, you’ve likely found the problem area.
Avoid touching exposed electrical connections while the washer is powered.
How to interpret the results
Test result
Most likely problem
120 VAC disappears at PCB
Power cord, noise filter, or incoming wiring
120 VAC present, DC supply missing
Main control board
Correct DC supply reaches display, but display stays dead
User interface board
Power returns when moving a connector
Loose terminal or damaged harness
Samsung’s troubleshooting information also identifies communication and control-board faults as possible causes of electronic failures.
Appliance Helpers
+1
My recommendation
I wouldn’t replace the pressure sensor, drain pump, or lid lock at this point. Those components generally wouldn’t explain why the entire display loses power for hours.
If you confirm steady 120 VAC entering the main board during the failure, and the display’s low-voltage supply is missing, I’d be comfortable recommending the main PCB replacement.
One question that would help narrow this down:
When the washer is completely dead, have you checked whether the main PCB has any indicator LEDs illuminated or flashing, or is the board completely dark as well?
That information, along with the voltage measurements, would help us determine whether the main PCB is shutting down or the display is simply losing communication with it.
