Samsung vrt plus doesn't drain [low frequency vibration/noise when trying to]
Brand: samsung
Model Number:
Main Symptom:
What happens & when: low vibration &sound when trying to drain, but doesn’t drain
Parts or tests already tried: cleaned out drain filter
The most likely cause for this issue will be a faulty drain pump that is faulty. To give more information, it would be helpful to have the model number of the washer.
