Samsung topload washing machine not spin
Brand: Samsung
Model Number: WA52A5500AV/US-00
Main Symptom: Agitator & drum not spinning
Error Code (if any): 9C1
Parts or tests already tried: We have tested the motor rotor & motor stator
The 9C1 error code would indicate a power supply issue. Check for an overload or under voltage issue. It sounds like there may be a control board issue.
Thank you so much, would this mean that we would have to replace the control board and if so would this be the correct board for my machine: WA52A5500AV/US-00
