Brand: Samsung
Model Number: RF268ABRS
Main Symptom: Fridge will show on display it is at the correct temperature but fridge and freezer both are warm.
What happens & when: The fridge will work okay for a couple of days but at some point even though the display shows 38 F/-2 F the fridge and freezer will both gradually rise in temp to the 50s and higher. After a power cycle the display will show the correct temperature in both fridge and freezer, and after period will cool back down to the set temperature. A day or two later the same process will occur again. I’m guessing a control board may be the problem, any idea which one?
