Anyone have the issue when ice dispenser won’t stop dispensing ice. What I had to do was switch quickly to water mode and it stopped. Went back to ice and it began dispensing again. Back to water and it stopped. Ok, went outside and flipped breaker. Waited 5 minutes turned back on and water on its own began to dispense. Wife quickly opened door to get it to stop. While door opened, switch back to ice, closed door, ice maker began on own again, so switched back to water and ice dispenser stopped.
Water isn’t pouring out either. Turned on child lock to prevent hopefully from this thing from working preventing disaster. Sorry for the long post, but what in the heck is going on. Switch stuck? .. Hopefully someone can explain what in the heck is going on and how to fix. Thank you for your time and help.
Thanks. Is taking off panel easy to do.. Don’t think I hear that click when pressed. Odd thing is, when it’s on water it won’t disperse water, unless I power down unit, start again then water flows without activating. Then quickly open door, switch back to ice, then close door, then back to water and that’s it. No water, but then if I want ice I switch to ice, then back to water to shut off. You’d think water dispenser would work, yet it doesn’t. Really worried on taking it apart, yet money tonight for service. What would you do to investigate it further. Thanks so much for the help…
