Samsung Refrigirator interior light will not come on
Brand: Samsung
Model Number: RFG295AARS
Main Symptom: Refrigirator interiou door will not light
What happens & when: opening the door
Error Code (if any): None
Parts or tests already tried: Replaced door switch, checked bulbs in a lamp, unplugged and removed light fixture and reinstalled. Unplugged frig for 5 minutes and plugged back up. Light will light partially for maybe 1 second and then turns off. The freezer light works.
When it does not light up, is there still voltage present at the socket? If there is a socket may be bad.If there is no voltage, a wire or control problem.
The issue might be with the wiring or control board for the refrigerator door light since the switch and bulbs are fine.
