Brand: SAMSUNG
Mod RF28HMEDBSR/AA
fridge stays ay 49, power cool works for a short time, no freezing up
and fan is working. freezer is working. no codes
Brand: SAMSUNG
Mod RF28HMEDBSR/AA
This sounds like an airflow, door seal, or sensor issue. Start by checking and cleaning vents, ensuring proper door seal, or resetting the unit (unplug for 5-10 minutes and then plug back in, give it up to 24 hours after reset)
https://www.appliancepartspros.com/repair-help/refrigerator-repair-help
thanks, I have vacuumed everything and door seals look good also unplugged couple of times. this has been going on for a month . control board issue ?? Sensor issue ?
You will need to check the sensors and if they are good the likely the board.
what sensors and do you have a # for the board
going to check the sensor now
