Just installed a new PCB Main Assembly in a Samsung Range Model #FTQ3531WUX. The AppliancePartsPros part# is AP5648803.
After installed the new part solved the issue of missing digits on the clock. However, now the oven light does not work. The oven “beeps” when you hit the oven light button, but the light will not come on. Also, doesn’t come on when the door is opened.
I re-checked all connections and the bulb is okay.
Anyone have the same issue or any suggestions what to check?
Greg R
