Samsung range heats to infinity and beyond!
Samsung ne58f9500ss :mad:
When you turn the oven on to say 350, the top element comes on and stays on well past 350.
The control panel is working, so I am able to turn it off, I don’t have to unplug it.
Sometimes it will stop at the right temperature, but more often than not it will just heat to infinity until I manually turn it off.
Prior to this occurring it was taking a really long time to heat up, say 30 mins to get to 350.
When the broiler gets “stuck” in the on position, the oven gets to temp in just minutes, but it keeps going well past my set temp.
Temperature probe has been replaced. That did not help.
It’s a sexy oven, i’m just concerned it is going to burn the house down.
Any ideas?
It sounds like a relay is failing. The relays are on this board.
Samsung DE92-02439G Assy Pcb MAIN;NE58F9710W - AppliancePartsPros.com
