Brand: Samsung Model Number: NE58K9430SS/AA01 Main Symptom: On any temp setting some of the numbers will not work What happens & when: example go to set a bake cycle and you hit 375 the 7 or 5 want work. Other features work just really the numbers not working
For clarification, when you say some of the numbers do not work-are you saying the display does not show those numbers, or when you press the keypad, it does not work? If by pressing the keypad, you don’t get a tone or indication the keypad is responding, then you are correct. My mind went to the numbers not showing up on the display
Yes I’m sorry I should have been a little bit more clearer. So yes the display is showing up it’s just when I go to press the numbers to set the temperature the touch pad is not responding.
