Samsung quits mid cycle
Thanks in advance for any help. I have a samsung dishwasher model #DMR57LFS. I installed it and ran the first load last night. I got 40 minutes or so into the cycle and the machine shut down. Lights, powerbutton, nothing worked. Tub full of water. So I unplugged the machine. Woke up this moring and I plugged it back in. The timer picked up exactly where it shut down last night. It ran for maybe 10 minutes and shut back down again.
I cant say for sure what else is on the same circuit, however I have a light plugged in the same outlet that works just fine.
Any ideas?
Thanks, R.
Cannot find info on this unit
Do not know if you have the unit hard wired in or are using a line cord.
In any case shut the power off to the unit and check the wiring where the power in is connected to the machines wiring. Often it is connected using wire nuts, remove them and make sure everything is good.
If OK check the power at the box to ensure you do not have a loose connection there.
If all OK put a service call in, if you go further you could void your warranty
Thanks Denman.
I’ll re check my wiring. Its not hard wired. I wired in a plug myself. If that checks out I think I try a different outlet via extension cord.
Thanks again.
