Samsung Oven heating problems NE58R9431SG/AA-00
Brand:
Model Number:NE58R9431SG/AA-00
Main Symptom: erratic heating behavior
What happens & when: When setting to BAKE oven won’t heat. Displays - 175 degrees. Tried setting to CONVECTION / temp set to “350”, then when it reaches temp, i change to BAKE at 350 and that works most of the time. Last night, I set to Convection / 400 and it sat at 175 for about 15 minutes, so i changed to Bake setting of 400 and it immediately displayed 400 and beeped that it had reached set temp (it was at 400 - measured w/oven thermometer). Bad control board??
Based on what you’re describing with your Samsung NE58R9431SG/AA-00, I would definitely suspect the oven’s electronic control board, but I’d check the oven temperature sensor and heating elements before replacing it.
The biggest clue is that the oven sometimes stays at 175°F, but when you switch cooking modes, it suddenly recognizes the correct temperature.
That tells us something important: The oven can reach the proper temperature, but the control isn’t always responding correctly when switching between Bake and Convection.
Here’s how I’d narrow it down.
1. Check the oven temperature sensor first
The temperature sensor tells the control board how hot the oven is.
  1. Turn off the breaker and let the oven cool completely.
  2. Locate the temperature sensor inside the oven, usually near the upper rear wall.
  3. Disconnect the sensor and measure its resistance with a multimeter.
  4. At approximately 70°F, you should get around 1,080 ohms.
  5. Warm the sensor slightly and watch the resistance. It should increase smoothly as the temperature rises.
If the reading is incorrect, jumps around, or goes open, the sensor or its wiring may be causing the problem.
2. Check whether the Bake element is heating
Even though Convection works, that doesn’t necessarily mean the regular Bake heating circuit is working.
Try starting a normal Bake cycle from a completely cold oven.
If the oven remains at 175°F and doesn’t heat, a failed Bake element, wiring connection, or control-board relay could be responsible.
If the Bake element works normally sometimes but not others, that makes an intermittent control-board problem more likely.
3. Check the control board
If the temperature sensor tests correctly and the heating elements are good, I’d focus on the main control board, particularly the heating relays.
For your model, the control board is listed as DE92-03960A, although I’d verify compatibility with your complete model number before ordering.
Sears PartsDirect
+1
With the breaker off, inspect the board for burned connections, loose plugs, or heat damage.
A technician can also check whether the board supplies approximately 240 VAC to the heating circuit when Bake is calling for heat. This is a live high-voltage test and should only be performed by someone qualified to work safely around energized equipment.
My recommendation
The fact that switching from Convection to Bake immediately produces the correct temperature reading makes me lean toward an intermittent control-board problem rather than a completely failed heating element.
One question that would help confirm this: When the display sits at 175°F, is the oven actually getting hotter while the displayed temperature stays at 175, or does the oven stop heating altogether?
That distinction will help determine whether we’re dealing with a temperature-reading problem or a heating relay that isn’t operating correctly.
Good feedback- thanks!
What would be a good way to “Warm the sensor slightly (and watch the resistance)” when there is no power to the oven?
To answer the question: When the display sits at 175°F, is the oven actually getting hotter while the displayed temperature stays at 175, or does the oven stop heating altogether? . . . it has exhibited both scenarios.
You can test the oven temperature sensor without having any power going to the oven. In fact, it’s safer to check the sensor resistance with the power turned off.
Here’s how I’d approach it on your Samsung NE58R9431SG/AA-00.
1. Warm the sensor and watch the resistance
  1. Turn off the breaker to the range.
  2. Disconnect the oven temperature sensor from the wiring harness. You want to measure the sensor itself, not through the control board.
  3. Set your multimeter to the 2K ohms (Ω) setting, or use auto-ranging if available.
  4. Connect your meter probes to the two sensor terminals. At room temperature (around 70°F), you should see approximately 1,080 ohms.
  5. Use a hair dryer on LOW or WARM to gently heat the sensor probe inside the oven for about 20–30 seconds. The hair dryer can be plugged into a separate outlet.
  6. Watch the meter while the sensor warms up. The resistance should increase smoothly. As it cools, the resistance should gradually decrease.
You’re looking for a steady change without sudden jumps, dropouts, or an OL reading.
You don’t need to get the sensor very hot. We’re simply checking whether it responds properly to a temperature change.
2. What your two different heating symptoms tell us
The fact that you’ve experienced both conditions is important:
  • Oven continues heating while the display stays at 175°F: This makes me suspicious of the temperature-sensing circuit or the control board’s interpretation of that signal.
  • Oven stops heating while the display stays at 175°F: This could indicate an intermittent sensor connection, a control board problem, or a heating circuit that’s dropping out.
Because you’ve experienced both, I wouldn’t replace another part just yet.
3. One additional test I’d recommend
With the breaker still off, check the sensor resistance again, but this time from the sensor wires where they connect to the control board.
This checks the sensor and its wiring together.
  • If the reading is approximately 1,080 ohms at room temperature and responds smoothly to warming, that’s encouraging.
  • If the reading jumps around when you gently move the wiring or connectors, you’ve likely found an intermittent connection.
  • If the sensor tests correctly at both locations, I’d be leaning more toward the electronic oven control board.
The temperature sensor for your model is DG32-00004C.
Sears PartsDirect
+1
One thing worth mentioning: During preheating, the display may remain at 175°F until the oven reaches that temperature. That’s normal. What’s concerning is when it stays there even though the oven has reached 350–400°F, as you’ve described.
My next question: When the oven stops heating at 175°F, does switching from Bake to Convection immediately get it heating again, or do you sometimes have to cancel the cycle and restart it?
That distinction will help us narrow down whether we’re dealing with a sensor feedback problem or a control board that’s intermittently failing to energize the heating elements.
