Samsung model:WF45B6300AW
Brand: Samsung
Model Number: WF45B6300AW
Main Symptom: Will not power up consistently.
What happens & when: The washer will not consistently turn on. It occasionally gives the power off beep sequence with no illumination on the front panel. When it does turn on all the buttons work, but when you try and start a cycle by pressing and hold the start button it just give a double beep. There is no other noise coming from the washer, not even the door locking mechanism. I’ve opened the PCB and confirmed that there is a consistent 123V going to the control board. All I can see is two blinking lights. One by the processor and one by the heat sink. This all start when the washer was running and stopped towards the end of the was cycle before the main spin. I was able to use the emergency latch to remove wet clothing since the door was locked.
My first thoughts would be the door switch and lock assembly or the drain pump, either of these can cause similar issues.
If you check the drain pump it should have a resistance value around 6.3Ω.
The door switch should have brown and black or brown and orange wires to it. Check the continuity on the terminals where those wires were connected to the door switch with the switch held closed, if you’re getting nothing check it for resistance.
Let me know what readings you get.
Yes I will check all of that and report back. Thanks!
I’m not getting continuity on the door lock assembly terminal, but I do get continuity when I check the hardness/wires that attach to the door lock. Hope that makes sense.
That makes sense. If the control board cannot see the door switch it won’t start. This sounds like an issue within the lock assembly DC34-00028A.
My apologies, after checking the door lock mechanism terminals for continuity I can confirm it has continuity. I wasn’t engaging the button that simulates the door being closed prior to my last comment. I suppose that means the mechanism is good?
