Unit is just over 1yr Samsung left me hanging, if I unplug the unit for ten min it seems to reset and then I can run it but it intermittently quits, running a spin cycle to get the water out of the dirty clothes that were stranded. I have electronics background so any tech help would be great.
One other note problem started with not beating able to start a wash cycle, would press start it will beep but won’t start, walk away for a few minutes and keep trying until it starts.
Can someone step up and try to help me, I need to get this fixed and no one has replied to assist. Thanks
Great forum absolutely useless if no one wants to help what a waste of time.:mad:
Well that’s because anyone has no idea what the problem is..maybe you wanna show us the trouble via pictures..if possible.
I was able to get the clothes out several days ago. The cycle will not start when the start/pause button is depressed. The it may or may not run a complete wash cycle. If it stops during the cycle the key icon in the upper left will be lit as well.
Hello there, one of my technicians is facing this exact issue that you experienced. I know this is a bit old now, but were you able to find a solution to fix this? Currently I am thinking of replacing the control board. Help is greatly appreciated on this one. Thanks in advance.
