Samsung icemaker replacement
I have a Samsung refrigerator/freezer and the icemaker support and icemaker try and mechanical unit need to be replaced. While working on the freezer I snapped the mounts for these items. So, they no longer stay in place!!
What are the correct part numbers needed to replace these items. When I do a search the parts displayed are different then the original part numbers. Part number stamped on support is DA61-02205A. Mechanical unit is NTGT001TA1.
Thanks for your help
Hi.
Here are the breakdown diagrams and 08-Icemaker parts for Samsung RS2556SH - AppliancePartsPros.com
I’m not quite sure what do you call “the mechanical unit”. Check the diagram, it should help.
Simon.
