Samsung ice maker
Brand: Samsung
Model Number: RF261BEAESR
Main Symptom: ice maker not filling
What happens & when: I tried reset procedures. The water dispenser seems fine. The ice maker assembly seems fine. How can I know if I need to replace the fill tube heater or the water inlet valve?
Parts or tests already tried: Tried reset procedures from samsung, assembly arm cycles but nothing else happens
Typically when a refrigerator icemaker will not fill with water, it is the fill valve. If the fill tube is iced up, it is still the fill valve. Try putting some water in the icemaker and see if it dumps the ice.
