samsung ice maker
AP4172188 (DA97-00258C) ASSY ICE MAKER I just replaced this ice maker I bought from this site. The ice tray will work if you click the manual button. However it won’t cycle on it’s own. Any ideas? I waited over night and didn’t make any ice. I also set the freezer temp to -10 degrees. After the manual cycle you hear a two beeps after it fills.
Have you had any luck? It appears that I am having a similar issue with my DA97-07365A Samsung icemaker. It started right after I replaced the water filter.
