Samsung Gas Range
Brand: Samsung
Model Number: NX60/A6511SS-AA00
Main Symptom: No display, Light turns itself on and off. Oven ignites, does not stay lit
Parts or tests already tried: Replaced main electronic board as Samsung tech said it was shorted out by roaches. But replacing the board did not fix the issue. It still does the same thing.
Hey there! Since you’ve already replaced the main electronic control board on your Samsung NX60A6511SS/AA-00 and the symptoms haven’t changed, I wouldn’t recommend replacing another board just yet.
The combination of a blank display, the oven light turning on and off by itself, and the burner igniting but not staying lit makes me suspicious of a power supply, wiring harness, or communication problem between the main control board and the display/user interface.
The fact that a technician found roach damage is also important. Insects can damage wiring, connectors, and multiple electronic components, not just the main board.
Here’s what I’d check next
1. Check the electrical supply. Make sure the outlet is supplying approximately 120 VAC and that the plug is firmly connected. A loose neutral or intermittent power connection could cause several of these symptoms.
2. Inspect the wiring harnesses. Unplug the range and inspect the wiring between the main board and the display/control panel. Look for damaged insulation, corrosion, darkened terminals, insect residue, or loose connections. Pay particular attention to the connectors at both ends.
3. Inspect the display/user interface board. Since the display remains completely blank even after replacing the main board, the display assembly or its power/communication circuit could be faulty. If the display is receiving the correct voltage specified in the service documentation but remains blank, that would make the display assembly a stronger suspect.
4. Check the oven ignition system. If the bake burner ignites and then goes out, we need to determine whether the igniter remains energized or shuts off along with the flame. A weak igniter, gas valve issue, or interrupted control signal could cause this behavior. However, the ignition problem may be related to the same electrical issue affecting the display.
Safety note: Because this is a gas range with unpredictable operation, I recommend leaving it unplugged and the gas supply shut off until the electrical problem is identified. Live-voltage testing should be performed only by someone qualified to work safely around energized appliances.
I have three questions that will help narrow this down.
  1. Is the display completely black all the time, or does it occasionally light up or flash?
  2. When the oven burner ignites, approximately how many seconds does it stay lit? Does it try to ignite again afterward?
  3. When the oven light turns itself on and off, does this happen even when the oven isn’t being used?
Those answers will help us determine whether we’re dealing with a damaged display/control harness, a separate user interface failure, or an electrical problem affecting multiple components.
Given that replacing the main board made absolutely no difference, I’d concentrate on the wiring and display circuit before purchasing another part.
Is this conversation helpful so far?
The display is always black. The light turns itself on and off at will, Its unplugged now. We have tried a different outlet, same issue. As for oven igniting, approx 30 sec. before it cuts off.
