Samsung Front-Load Washer Safety Door Replacement
I need to replace the “safety door” on my Samsung front-load washer. The part does not come with installation instructions and I do not want to pay a repairman. This is a clear plastic front piece on the door. Can anyone help?
[LEFT]1. Separate the 2 screws holding the Hinge and the Front Cover.
2. Separate the Door Assembly lifting it up slightly.
3. Remove the 15 screws fixing the Door Cover (including the 2 blue screws holding the Door Lever.)[FONT=ArialMT]
4. Separate the Door Cover and remove the 8 screws to separate the Hinge.
- The door safety AP4483958 [/LEFT]
Gene.[/FONT]
Thanks, Gene, for replying with help to replace the door. Greatly appreciated!
Scott P.
Florida
You are welcome Scott. Keep us posted.
