When I go to start a load the water will just keep running until it get so high then “OE” comes up on the display. The pump will then start running and drain the water but it continues to put in cold water. I can turn it off or unplug it and the water will stop. So far I have replaced the level sensor (I also blew through the hose that’s connected to the senor to make sure its clear and it was), the cold water valve assembly, and the Computer board in the front. None of these things have helped! I really don’t want to have to go buy another washer because these set is blue and I’d have to buy another dryer to match:mad: . PLEASE if someone could help me I’d sure appreciate it.
I took the front off and checked the hose from the water level sensor all the way to the drum is ok. I’m stumped.
PLEASE SOMEONE HELP!!
I took the pump off and cleaned out all the hoses and re-installed. Assembled the front and started a load and no change. Once it gives the command to turn on the cold water it never turns it off. Looking at new washers now:mad:
Man I was hoping that someone of here could help, I guess No One has every encountered this problem.
