Samsung Flex Oven SE Code Error
The power went out at my house and when it came back on, the samsung flex oven I have got an SE code. I have unplugged it and plugged it back in, shut off breaker and turned back on, checked wiring to touchpad and sub panel and the SE code keeps coming back. It looks like I have to order either a new touchpad or sub panel but I’m not sure which one causes the SE code. I don’t want to order one and still have the code and have to order the other. Any thoughts on how to fix it or which one I have to order?
KWB77,
FYI you need to repost this in the range ovens section. You’ve posted in washing machines section.
Ok so in answer to your question the SE error code means that the system is detecting a button has been pressed for more than 10 seconds. To reset try pressing the clear/off button. This should clear the SE error code. If not it may be that UI is bad (touch pad). A button may be stuck..
