Brand: Samsung Model Number: DW80J7550UG/AA-01 Main Symptom: Leaking water. What happens & when: Water leaks during cycle. There is a seal at the bottom the width of the door that is degraded and has come off. Having trouble finding correct part.
I would also like to mention that this seal is different than the door seal that wraps around the sides and top. This seal is flat looking and was either connected to the bottom of the door, or at the base of the tub.
