The defective roller that I intend to replace isn’t the OEM part. It doesn’t have the bearing. The wheel’s inner bushing is simply riding on a shaft. The roller has two washers. Should those washers be transferred on the OEM part?
What part of the drum the roller wheel should be in contact with: the felt seal or the metal surface behind it?
