Samsung Dryer numerous issues- PLEASE HELP!
Brand: Samsung
Model Number: DV42H5600EP
Main Symptom: numerous issues
What happens & when: see below
Error Code (if any): none
Parts or tests already tried: replaced both control boards and the thermostat
Samsung Dryer DV42H5600EP/A3
Try to select Delicates, pops to Refresh. Try to select Wrinkle Away, pops to Wool.
Very Dry (dry level), High (Temp), and 50min and 60min (Time) aren’t available with any cycle selection.
Quick Dry cycle shows 40min on screen but 30min on Time
Time dry defaults to 20min but doesn’t allow for any other options (Dry level, Temp). Time button only works for 20-40). But 20 shows 20, 30 shows 40, and 40 shows 100. Will not go to 50 or 60. Rack Dry and Anti Static aren’t available in Time Dry. There is no heat when running a time dry cycle.
Eco Normal and Quick Dry allow for temp selection up to and including medium, but not high. There are no Dry Level options.
There is heat when running Normal or Heavy Duty, but can only select up to 40 minutes and the dryer cuts off after only a few minutes, especially when drying sheets. It’s impossible to do laundry!
Have replaced both boards and the thermostat.
Have cleaned vents and ducts.
Have done a hard reset.
Have held temp and power for 5-10 seconds.
Could you give me the part #s of what all has been replaced for this issue?
DC92-01607C Dryer Display Control Board, DC47-00015A Dryer Thermostat, and DC92-01626A Dryer Main Control Board.
That main control board part # DC92-01626A is not listed as compatible with this model. The control board for this model is DC92-00669W. The display control board and the thermostat that goes on the heater housing each appear to be correct.
https://www.appliancepartspros.com/samsung-assy-holder-pcb-dc92-00669w-ap5916735.html
Since we had installed the front control board twice, I ordered another back control baord and he installed it just now.
The issues remain the same.
Please help!
At this point it sounds like electrical interference. That could be a low voltage DC load that has failed and is dragging on the system, wiring within the dryer, or potentially a source electrical issue.
The only 2 DC loads that I’m seeing are the thermistor on the blower housing and the moisture sensor bars on the lint filter guide. The thermistor should read about 10kΩs around 77°F, and the moisture sensor bars should read continuity if you lay a damp cloth or rag across them to form a bridge and take a reading.
After that the issue is most likely due to a wiring harness that may or may not be visibly damaged or some kind of source electrical issue. If the thermistor and the sensor bars are good, and you can’t find any visibly damaged/pinched/broken/corroded wiring, I’d suggest contacting a technician with a repair company or an electrician to test the outlet under load.
