Brand:Samsung
**Model Number:**DVE50M7450W/A3
Main Symptom:Heating Problems
Parts or tests already tried: Heating Element, Thermal Fuse, Thermal Switch, Thermistor
I have been fighting this dryer for some time.
About 2 years after purchasing, it stopped heating. I found the heating element was open and so replaced it. I thought it was a bit early, but whatever….
About 6 months later, the heating element went bad again. Now more suspicious, cleaned the vent from inside house and from the roof, there wasn’t really much lint in it. Put in another element and went on.
About 8 months later, it stopped working again. Now becoming irritated, I took it apart again and surprisingly, the heating element was OK. This time the Thermal Fuse was blown. I put a new one, again cleaned out lint from inside the dryer ducting, around the filter, and in the wall vent too. Again, not much there, but seemed like poor airflow might be the problem, so did it again. Put in a new fuse and it worked for 3 days. Ugh, decided to buy the Samsung OEM thermal fuse for $50 and put that in. That lasted 2-days. I tested the thermal switch with hot air and IR thermometer, it opened and closed as expected. Repeated several times. I ordered a bunch of the cheap fuses and decided to run dryer pulled out from the wall to be sure no vent issue. Ran three loads of clothes through it, so it ran between 2 and 3 hours and the fuse blew again. Put another fuse in, ran the dryer with no clothes in it and pulled out from the wall. I noticed that the exhaust air was hot at first, but then went cold after around 2 minutes. After another 2 minutes or so, it heated up again. Ugh, decided to order a new Thermal Switch even though the old one tested good. I put that in, ran the same test again, same result, the exhaust was hot for a while, then cool for a while, repeat. The 2 minutes of heat followed by a similar time of cold air seemed to be too slow for the thermal switch based on my testing with hot air. When I tested it with hot air, it was more like 15 seconds to go from open to closed, but I tested it in open air, not in the ducting.
I took the thermistor out and measured it. It measures 10K at room-ish temperature so seems OK, but I am ordering a new one of those as well.
Anyone have a theory that fits all these symptoms? Were the two heating element failures unrelated to the blowing of the fuse and the heat coming and going? I didn’t let it run long enough to know if the thermal fuse would blow again with dryer empty and pulled out from the wall, but assume that it would blow again after a while.
Thanks for any help
