**Brand:**Samsung Model Number: DV42H5200GWA2 Main Symptom: Only completes drying cycle in delicate. What happens & when: Runs and drys in delicate only ,in normal give a code I can not find ,it runs I can hear the burner light for about 2 minutes then code shuts down.
Error Code (if any): 6E ,bE, the first letter seem not to light.
Parts or tests already tried: Cleaned all lint to the outside vent, checked three sensors ,watched cycle with a mini video
camera .
The error will be a tE error and is a thermistor error. You will want to check to make sure that the thermistor is good and if not then it will need to be replaced. The resistance of the thermistor will be 10K ohms of resistance. This is the sensor located on the blower housing. Dryer Parts - OEM Replacement Parts
I checked that and it read good ,I give up it ran 3 loads today in delicate ,the clothes were dry in 45 min. I can hear the burner go on and off and on ,in normal it error’s out ,I will run this POS in deicate till it quits then junk it after I destroy it ! thanks for your effort !
