Samsung DMT400RHS Dishwasher Over Level Water Error
What are possible Root Causes for this? Two lights are Blinking: “Heavy” and “Smart Auto”. Owner’s Manual is not very helpful to the DIY’er–manual says shut off power and call repair person.
Thanks in advance for any help. Tired of washing dishes by hand!
Cprodave, if the water is not overfilling the dishwasher and the valve does not leak water by, the flow meter on the case brake would need to be tested for voltage. If it measures 3.5VDC or less when water is not flowing through, the case brake would need to be replaced.
