Samsung Brand:
DW80K7050UG
Model Number:
Main Symptom: won’t drain
So last week I had the leak detector error code. Ordered a new sensor. Didn’t fix it. Cut the connectors off and hard wired it and the error went away. However now it doesn’t drain. I ordered a new pump for the drain and replaced that today. It appears all the lines are clear. I took the line off that runs from the pump to the plastic loop piece and no water came out. Is there a check valve? I’m not sure what I am missing. I can hear the pump kick in.
