Hi guys new to the fourm. My pilot light will not stay lit. I have just replaced the pilot assy(bought from here). It still wont stay lit. I have only used the oven once or twice before. Not to sure where to go from here.
Thanks Robert
Thanks Robert
Anybody???
If nobody has any sugestions I guess I will just keep replacing parts tell its fixed.
The same thing happened to me and the fix was easy. Turn the knob to the pilot position and then pull the plastic knob off. The mechanism will push in further with the knob removed. This will give you a tall pilot light and it will better heat up the thermocouple. Let it heat up for 10sec or so and then turn the knob and your oven should light up.
tryed that no go. Even heated the probe up with my torch and still it goes out when I release the knob.
