Hi over the weekend I cleaned out the dishwasher and was wondering can the rubber check valve be installed the wrong side? If yes would that cause the water to stay in the dishwasher? I can hit the drain button and the water does drain into the disposal and I can see if drain from the air valve. What could be the issue I’m having? Thanks.
A model number may help others help you
Find your model number - AppliancePartsPros.com
[COLOR=“Blue”]can the rubber check valve be installed the wrong side?[/COLOR]
Not sure what you mean by wrong side.
[COLOR=“Blue”]
If yes would that cause the water to stay in the dishwasher?[/COLOR]
If installed backwards it could cause a drain problem.
[COLOR=“Blue”]
I can hit the drain button and the water does drain into the disposal[/COLOR]
If the valve was back ward then it would never drain as the check valve would act as a plug though I cannot be 100% sure of this without more info.
[COLOR=“Blue”]
and I can see if drain from the air valve.[/COLOR]
Sorry but again I do not understand the above
