dryer works ok on timed dry but runs forever on autosense dry vent new no clogges plenty of flow whats up thanks
Parts for Roper RED4440VQ1 Dryer - AppliancePartsPros.com
See the attachment for your tech sheet.
In timed dry the timer motor gets power all the time through the timer’s contacts T to F
In auto modes the timer motor gets power through the heating coil when it is turned off via timer contacts T to X.
First I would unplug the unit.
Disconnect the wires at the heater and measure it with a meter, should be around 8 to 12 ohms. Also check each heater connector to the frame, both should be infinite ohms.
Sometimes a heating coil can break and short to the frame in such a way that it still seems to run OK but is actually running off of 120 volts. Your timer motor need the full 240 volts.
If the heater is OK then reconnect it and set the timer to a mid-scale auto cycle. Remove the wires at T and X on the timer and measure across the contacts, should be 0 ohms.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
EED4300.pdf (548.9 KB)
