Roper washing machine
SPIN CYCLE NOT STRONG ENOUGH TO GET WATER OUT OF CLOTHS. USED LITE LOAD STILL THE SAME.:mad:
Hi.
First remove the agitator and check if the drive block is not stripped AP6008836
Next - check the motor coupling AP3963893
If those are OK - replace the clutch AP3094537
Here are the breakdown diagrams and Replacement parts for Roper RAS8333RQ0 AUTOMATIC WASHER | AppliancePartsPros.com
Post the results.
Simon.
Thanks Simon, Will try to repair following your instructions. From the looks of what Iv’e seen so far it looks like the plastic agitator rings are stripped. will look at the remaining parts instruction tomorrow, parts shop closed for week-end. Use APSCO appliance parts store. RichardH43X
